Salta al contenuto principale
Is this tv repairable?
something was thrown at the tv causing it to now be broken.. it has like a rectangle chunk of lines going from top to bottom but stops about mid screen up until the point of impact where there’s like a circle crack where the object hit, they’re like a blueish color. There’s no sound and no picture.
Questa è una buona domanda?
Punteggio 0
2 Commenti
My 70 “ Tv screen is cracked can it be replaced?
da
I’m having the same problem I have a 70in Vizio Model# V705-G3 Serial# LFTRYSLV4406042 where can I purchase a screen at I live in Palm Bay, Florida
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@tharris123 what you are describing sounds like a broken panel. Panels this size are almost non-existent for repair and even when available they cost considerably more than a new TV. I suggest that you remove all the boards from the TV and sell those individual on place like ebay.com or others. Use that money toward buying a new TV. Discard of the old panel properly.
Punteggio 5
7 Commenti:
Thank you. Is there a way to estimate how much I would get if I sold the boards? I have no experience in this whatsoever.
da
what is the exact model?
da
VIZIO 70" Class 4K (2160P) Smart XLED Home Theater Display (E70-E3)
da
The LED array behind the panel is probably worth something too, if you can get it out.
da
You can purchase a complete set of new power board, T-Con board and Power board for ~$110 USD and complete replacement LED backlight strips for~$70USD so no fortune to be made on used board.
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Tavia Harris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,014
