Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Domande Visualizza tutte
Can I replace the 500GB SSD with a 1TB SSD
I've got an iMac 27" (late 2013, model 14.2) that already has an onboard 500GB SSD (APPLE SSD SM0512F).
Is it possible to upgrade this existing SSD to larger one, i.e. 1TB SSD? If so, what 1TB (or 2TB) SSD is compatible?
Questa è una buona domanda?
Punteggio 1
1 Commento
Here's the specs for your system: iMac.2
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Before we go down this path lets first review what it will take to get to the custom Apple PCIe blade SSD: iMac Intel 27" EMC 2639 SSD Replacement its quite a lot of work! And if you've never opened one of these newer 'Thin Series' iMacs its a bit risky as you need to be very careful taking the display off. Many people have damaged it in the process which would be a very expensive mistake!
While the SSD is replaceable the special SSD is not easy to find in the larger sizes. Review your SSD going to 'About This Mac' > System Report. The SSD your system has if I remember correctly is a PCIe 2.0 x4 (4 lanes) so far the 3rd party companies only offer a 2 lane part so while they offer larger sizes the I/O speed will be slower. And they are expensive as well!
So what about adding a second drive? While not as fast SATA III (6.0 Gb/s) it might be good enough to host your data. Leaving the SSD as your boot drive hosting your OS & Apps. You could go with either a SSHD (3.5") or if you want a SSD (2.5").
If speed is the more important then you need to go externally! The Thunderbolt port is faster than the internal SATA port and very close to the PCIe SSD (depending on the drives you use). I would recommend going with either a 2 bay or 4 bay RAID unit and put your own 2.5" SSD's into it.
Punteggio 1
2 Commenti:
Thanks Dan. The System Report for the SATA Express, has the following:
Apple SSD Controller:
Vendor: Apple
Product: SSD Controller
Physical Interconnect: PCI
Link Width: x2
Link Speed: 5.0 GT/s
Description: AHCI Version 1.30 Supported
So is the Link Width (2) the same as "2 Lanes", or a different attribute?
Overall I think you're correct in that going for an external SSD via Thunderbolt will be the way forward. Awesome response, thank you.
da
Yes, link width is the PCIe lanes.
da
Risposta Più Utile
It has an official 1TB SSD option available, so once you find the correct part, it should be trivially easy to swap the SSD once you take the screen off.
However Apple SSDs are custom parts, they are not much cheaper than just buy them new with the computer, so it’s actually cheaper and easier to buy an external SSD and just plug it in through USB3.
Punteggio 2
1 Commento:
Thank you Tom.
da
Aggiungi la tua risposta
Andrew Forkes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,225
