Salta al contenuto principale
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
power socket smashed need replacement
My nephew brought me his nintendo dsi and the power socket on it go smashed somehow and it is unusable. I have bought the replacement part which is said to require soldering but can find no guide anywhere (pictures or video) on this matter. Can someone give a detailed description on exactly how to go about this. Thank you.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
Sounds like you need this part: Nintendo DSi Power Board
Here's how to install it: Sostituzione della scheda di alimentazione del Nintendo Dsi
Immagine The power input board includes the D-pad & On/Off control button contacts.
Prodotto
$17.45
Punteggio 2
Okay I know i answered this on here before somewhere....:-) here are some instructions about the soldering http://surugi.com/projects/DSLiteUSB.htm... and here is the plug http://www.buy.com/prod/repair-power-con... substitute ti USB plug with the original power plug. Anyhow it gives you an idea of what is involved. Good luck and let us know what (and what does not ) work for you.
here it is How to Replace the DSi charging socket on the motherboard?
Punteggio 1
Aggiungi la tua risposta
john sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 20
Tutti i Tempi: 5,766
