Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Looking for an enclosure for MacBook SSD?
So my Macbook Pro Late 2016 has recently died from a water spill, I'm trying everything but I think the logic board is fried. I'm wondering if there's a way to potentially retrieve my data from the SSD, since it's able to be removed, and if so which enclosure or reader would be best for the one in this model (Late 2016, A1708). I've been looking around online and I found some for earlier models but I want to be sure before I order which one is right for this model. Any suggestions or recommendations would be greatly appreciated!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Oh No! Not good...
OWC is one of the few companies which make cases to house Apples custom SSD's. Sadly, the new function key model uses a still newer physical connection than what OWC offers in their cases so there is no means to gain access without leveraging a second MacBook Pro 13" Function Key system to host your SSD (swapping them out) then copy off your stuff to an external drive then pop the original SSD back in (if its larger).
Punteggio 2
2 Commenti:
Dang, any update on if there’s any enclosures about for the SSD now?
da
Sorry no external case
da
I can help you getting your data of the device if you send me the ssd as I can put it in my macbook and send you all the important stuff you want :-) Sounds better then spending a lot on a new macbook just to void it's waranty because of swapping it's ssd out with the one of your liquid damaged macbook right?:-)
Cheers
Punteggio 1
4 Commenti:
Sorry but I really don’t feel comfortable sending a complete stranger on the internet my hard drive with my personal information on it...
da
No problem, was just trying to help out. Maybe ask some friends with an similiar device?
da
Musti, do you know that this will actually work?I have the same story as OP but I have another macbook pro coming in the mail so I want to know if you have tried this before and that I can actually access the data on the drive?
da
Looking for an enclosure for this drive to get my data off as well. Any luck?
da
Aggiungi la tua risposta
Taylor Manning sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,493
