Salta al contenuto principale
The HTC Vive is HTC's first virtual reality headset, co-developed with Valve and released in April 2016. The device's model number is NM80PJT100.
The power button is loose and won’t turn the Vive on.
The power button on the Vive presses with no resistance, and it doesn’t turn the device on. All the cables are plugged in. What could be the problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
If there is no feedback from the power button, then the outer shell has probably been knocked out of place. The button is attached to the shell and is supposed to be over the power switch, but the button can fall out of place. You can follow the steps in the Sostituzione guscio esterno HTC Vive to set the outer shell in the correct place again.
Punteggio 0
Aggiungi la tua risposta
Gabe Musen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 514
