Salta al contenuto principale
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 Domande Visualizza tutte
My phone is unable to connect to mobile networks, probably hardware issue
My phone is unable to connect to mobile network and it is probably hardware issue, cause i flashed everything twice.( I mean os) it occured with signal going for short time then came back again but now no signal at all...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
so there is a few things that can be the cause of your symptoms.
1) Be sure to make sure the device is either unlocked, or locked to your carrier.
2) Look into the national blacklist. If you got the device second hand, there is a chance it was reported stolen.
3) Software corruption. Run a factory reset on the device.
4) Disconnect. Make sure there is enough pressure on the metal traces lining the housings, to the board.
5) Coaxial breaks. Look for coaxial cables, test continuity, and replace them as needed. (make sure they arent loose first)
6) Antenna failure. Check for board antennas. sometimes a reflow of these parts will fix the issue.
7) Network IC failure. Board level failure is pretty common. you will need experience with SMT to replace the Components in the networking Circuit. most people will scrap at this level of failure.
Punteggio 0
Aggiungi la tua risposta
Ahmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 103
