Why doesnt work GSM signal?
Hi, on my iphone 3g work 3G signal good, but GSM signal doesnt work, can I fix it with this part? This is an 8 GB model.
http://i55.tinypic.com/2h6bx9y.jpg
please answer, thanks
Questa è una buona domanda?
SmSn check on here Can't pick up service signal looks like a problem similar to yours with a solution Good Luck
Hi, but i have problem with GSM only,
If you received it before and if your carrier has not made any changes, I would start thinking about changing the dock connector. Of course not knowing where you are located, you could also check with your carrier, may be a Sim card issue. Good Luck
dear old turkey :) hello could you please help ?
i have fixed an error -1 in itunes ,which is bb issue ,the wifi was weak so i fixed it !! but the gsm is constently losing signal !!!what seems to be the issue ?
thanks
p.s the first issue was water damage ,,
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,941
