Salta al contenuto principale
Freezes running OS 9.2
I have an older iMac, 500Mhz, 'Blue'. With 20 GB HD with ~15GB available. 640 MB memory, Virtual Memory is OFF. I am running OS 9.2.1 and it freezes while trying to do a software update. There is no System X on it.
I recently purchased a couple of games that will not run in OS X or in Classic but since I have this iMac, i figured no problem since it could simply become a OS 9 machine.
I knew it froze in OS X (Jaguar) but had not had problems in OS 9.2.
Now it freezes. I tried the recommendation from the Nov 2, 2010 post (iMac freezes after a couple of minutes) but this assumes I'm running OS X. The OS 9.2 Disk Utility does not have repair permissions
Ideas?
Questa è una buona domanda?
Punteggio -1
7 Commenti
I am running OS 9.2.1. I did a re-install from my Gray disks that came with the machine (was OS 9.2.2 before the re-install). Will try the system update with extensions off.
da
With extensions off, the computer says it is not connected to the internet thus will not do a software update.
da
Yes. I only did a system re-install. Not a complete hard drive re-write. All disk utility checks have found nothing, all are sat. My next step was to do a complete HD wipe and re-install. Tomorrow.
I do have a retail disk of OS 9.0. I tried it on my iBook (G4, 1.2GHz) but could not get the machine to startup holding the command C down while starting up. Now that iBook's firewire port does not work either. Go figure.
da
Could this be a firmware issue (iMac)?
da
Explains why I couldn't get the iBook to start up on OS 9. Yes, I booted and loaded OS X on it already (10.4). I'm assuming my Dually G4 1Ghz Quicksilver wouldn't run OS 9 either? Zeroing out the iMac as I type. Will do a complete OS 9 re-install once complete.
No go. Zero'd out the HD then re-installed all software. Then tried a software update only to have the iMac freeze. Will try to re-format the HD using OS X utilities.
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
First what is your current system? Was it installed from a retail disk or a gray disk? A system reinstall would probably solve your problem. Start up holding down the "Shift" key to turn the extensions off and see if it locks while doing a system update.
Punteggio 1
2 Commenti:
The only difference between 9.2.1 and 9.2.2 was some printer drivers. Are you still having problems after the reinstall?
da
The iBook G4 1.2 will run OS 9 in Classic mode only. It will not boot from it. Run OS 10 Disk Utilities on it to get it back up and running. On the iMac - Reformat the drive and use the "write zeros" option to map out any bad blocks the reinstall the system. Mac OS extended.
da
Aggiungi la tua risposta
StevieB in ABQ sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,493
