iMac will not boot properly
My iMac will not boot properly. It starts up and there is a chime but the progress bar will not get more that a third of the way then it stops. It starts in recovery mode and it starts in safe boot which suggested to me that it was a software issue or a problem with the boot partition. I have replaced the internal hard drive and installed a completely new system (Yosemite) but still it will not get any further under a normal boot.
I have noticed that there is no "Built in Speaker" option available in the System Sound preference. Would a faulty sound card cause these kind of symptoms during boot up?
If so do you have any way that I can verify that this is the problem?
Update (09/28/2017)
Hello Dan. Thanks for your reply. I cannot get the iMac to boot in to diagnostics mode. I don't think it will do it without the installation discs (it's actually my sister-in-laws mac and she is trying to find the original discs).
I have run TechTools Pro though and that did not return any errors. On the recommendation of someone else I also ran EtreCheck and that too returned no errors.
The drive that came out was an apple installed 320GB WD3200AAJS-40VWA1 which I replaced with a 1TB WDC WD1001FALS-40K1B0 drive. I replaced it because the original drive was almost full.
However, the startup issue was there before I replaced the hard drive so that would suggest to me that it must be some kind of hardware error.
Update (09/30/2017)
I have waded through this log but I am none the wiser. This is the log from powering up to the point where there appears to be no more activity and I have to force shutdown. Not sure if this is helpful or not.
Update (10/03/2017)
Hi Dan,
Thanks for the advice. To be honest I'd pretty much gone through this process already but not with El Capitan. I still have the original hard drive which I can access all of her files from if I mount it as an external drive so I'm not concerned about that aspect too much.
After having run the El Capitan installer the progress bar appears to freeze but then I get the audible voice over instruction even though the first page of setup is not showing. I left it for a while thinking it may catch up. When I returned and woke the mac the screen had changed to the county location but would not let me select anything. I moved the cursor keys up and down but nothing happened. Again I left it and then came back to wake it and Ireland was highlighted (it was showing United States) but still no movement.
It is almost as if the system is working but the video is freezing.
One thing i did notice in the log file was in the last portion it mentioned something about Window Server creating a screen shot. (See below) Do you think the firmware could be damaged?
30/09/2017 11:34:59.144 mds[53]: (Volume.Normal:2464) volume:0x7ff30a894000 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/firmwaresyncd.rdaZe230/09/2017 11:41:08.814 WindowServer[129]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)30/09/2017 11:41:08.818 WindowServer[129]: device_generate_lock_screen_screenshot: authw 0x0(0)[inf, inf, 0, 0] shield 0x0(0), dev [1680,1050]30/09/2017 11:41:48.867 watchdogd[142]: [watchdog_daemon] @( pm_callback) - ref=0x0 msg_type=0xe0000270 msg=0x27000530/09/2017 11:41:48.868 watchdogd[142]: [watchdog_daemon] @( pm_callback) - ref=0x0 msg_type=0xe0000280 msg=0x28000430/09/2017 11:41:48.868 watchdogd[142]: [watchdog_daemon] @( wd_daemon_thread) - events buffer: 18r944 668s94430/09/2017 11:41:48.000 kernel[0]: PM response took 106 ms (62, coreduetd)30/09/2017 11:42:05.000 kernel[0]: PM response took 1831 ms (47, powerd)
Questa è una buona domanda?
1 Commento
Your systems specs: iMac 20" 2.4 GHz Core 2 Duo" Alum (Mid 2007)
da Dan
