Salta al contenuto principale
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90 Domande Visualizza tutte
Where to buy replacement speakers for JBL Charge 3?
Where can I buy replacement front speakers for the JBL Charge 3? I have been trying to research where to buy, and have been unable to find a place to get them. I think one of mine is blown.
Questa è una buona domanda?
Punteggio 6
6 Commenti
I want to know the same thing. Cheers, TQ
da
Yeah mine got a hole in the left speaker but no where to find
Cheers,
HJ
da
Looking too. The charge port completely fell off. I can no longer charge my JBL3 :(
da
You can replace the charge port, get the part on Amazon as well as the battery. Speakers you can find on Ebay.
da
Hello, you can easily get speakers for JBL Charge 3 on the following website.
Original spare parts : https://ecommerce.mysav.eu/en/jbl/147-sp...
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Risposta Più Utile
Mike, the charge port is readily available and an easy fix. Watch the youtube video on how to do it and get the replacement charge port here in the States.
Henkjan, I found some replacement speakers from China that were the right dimensions for the Charge 3. Had to knock off the little guide post off the JBL frame that went through the speaker frame, but that is no biggie. I also put some flat washers (two in each corner) between the speaker and the JBL frame. Still had enough compression on the seal to keep it water resistant. Good luck.
Cheers,
TQ
Update (07/30/2019)
Here are two of the ones I bought that will fit:
https://www.ebay.com/itm/162694336905
https://www.ebay.com/itm/254053310184
As mentioned, the little "posts" on the JBL frame must be removed, or a hole would have to be drilled in the speaker frames to accomodate the posts.
Cheers,
TQ
Punteggio 2
4 Commenti:
Hi Trevor,
Can you post here the link of the site where you've found right dimensions speakers for the Charge 3?
Thank you
Max
da
Please share the link! My Charge has been sat in pieces for over a year now and to find some speakers (finally) would be so much appreciated!
da
Trevor, you're a king! Ordered mine just now, thank you so so much!
da
Hi Trevor. How would you rate the sound quality of the speakers ordered from China, compared to the oem jbl speakers? Better/worse/same?
da
Hi,
try Simply Speakers, there can be some spare parts for JBL.
Punteggio 0
Aggiungi la tua risposta
Gabriel Tovar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 7,616
