Salta al contenuto principale
Apple Watch Series 2, annunciato il 7 settembre 2016 e lanciato sul mercato il 16 settembre 2016.
132 Domande Visualizza tutte
Would replacing my screen jeopardise the watch’s waterproof properties
I have a large, deep scratch in the screen of my Apple Watch series 2. It has started to get on my nerves, and I have begun to consider replacing the screen myself. Would replacing the screen cause the watch to no longer be waterproof?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
First it is water resistant not waterproof
https://support.apple.com/en-us/HT205000
If you do the repair, any remaining warranty you have will be kaput.
Replacing it yourself and getting as good a seal as the factory did is unlikely.
The part is out of stock and expensive. I'd call Apple as see what they are charging first.
Punteggio 2
There's no way to guarantee that it would still have the same water resistant rating. Also, the replacement adhesive strips I have found so far are a bit thicker than the OEM one. So after you re-set the screen in place, it sticks up a teeny, tiny bit higher than it did originally. Literally, we're talking a fraction of a millimeter, but it is enough to feel. And if you really look closely, you can see the difference too. Does that matter? Maybe, maybe not, but personally, I worry a little bit about the edges of the screens being that much easier to chip.
Personally, before I did anything else, I would try picking up a good screen protector (probably one of the plastic ones like the stuff from Armorsuit, not a tempered glass one) and see if that covers up the scratch enough to not bother you so much.
Punteggio 2
Aggiungi la tua risposta
Luke Rogers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,205
