Salta al contenuto principale
La Panasonic Lumix DMC-TZ5 è stata rilasciata a marzo 2008. È la terza fotocamera della serie TZ, dotata di uno schermo da 3,0 pollici, obiettivo 28-280 (zoom ottico 10x) e 9,1 megapixel. La TZ5 dispone anche della registrazione video in HD a 720p.
When I turn in there is a screen asking for a code. How to enter code?
The screen shows some ok ok line and at the bottom there is firld for 'Code'.
What is code!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@mkh12 I've checked the manuals and I can not see anything that would require you to enter a code. The only code that this camera might show is a fault code. I would suggest that you remove the battery to reset your camera and see what you get. You did not tell us when this code comes up. if ti does so right at start-up or somewhere in the menu. Try to reset your camera by following these steps.
Punteggio 1
2 Commenti:
When I turn on the canera there is a screen on top of the menu options showing the few things:
State: Idle
LogDir: HS00
HsCmd: ok
Hsnet: ok
HTTPc: ok
Code :
What are these?
How tonget rid of this window and goto normal mode?
Is it busted?
Please let me know.
da
that sounds like a diagnostics menu. Let me check the service menu later for. this is a DMC-TZ5?
da
Aggiungi la tua risposta
Md Kamrul Hasan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 13
Tutti i Tempi: 340
