Salta al contenuto principale
A 35mm FD-mount single-lens reflex camera introduced in April 1984 as the second in Canon's T series.
8 Domande Visualizza tutte
Where to find replacement parts
How do I replace old parts on this older model camera?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hannah Bynum you did not tell us which part. This manual 1.EPS should have all that you need to repair your camera.
Punteggio 2
2 Commenti:
It needs a new battery cover, off/on switch, and socket cover
da
Check for the numbers in the parts list in the SM. For example, the battery cover is part number CY1-1164-000 and available at places like this Not sure which socket cover you need but it might be part number CA4-1847-000 available at the same place.
da
tenho uma toda funcional , prisma com muito fungo e lente um pouco o restante toda ok . se interessar….
Punteggio 0
Aggiungi la tua risposta
Hannah Bynum sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,635
