Salta al contenuto principale
Lo Huawei P8 Lite (2017) è uno smartphone Android entrato in commercio nel gennaio del 2017. Ha uno schermo da 5,2 pollici con una densità di ~424 ppi ed una fotocamera posteriore da 12MP.
20 Domande Visualizza tutte
Huawei p8 lite 2017 touch screen not working
A friend asked me if i could repair his p8 lite 2017 and bought a brand new display+frame (broken glass, touch screen perfectly working)
The touch screen worked before the repair, now nothing even with a brand new part
The old screen doesn't work either now so i think it's a software issue of some sort
Cables are clean and perfectly fitted
Anyone had the same issue?
Questa è una buona domanda?
Punteggio 2
1 Commento:
I have the same problem, some solution?
da
Aggiungi un commento
4 Risposte
Lcd new but touch no work i changing 3 lcd all same y?
Punteggio 0
Hi.
your phone seems to have a broken screen output ribbon, which means that it can’t output feedback on touch, but it still turns on.
The only thing you can do is replace the screen.
Did your phone fall some time?
Does it have a dent or scratch on the side of the screen or near it?
Punteggio 0
I had tested this issue by changing the mother board and it works. My touch is working perfectly on new mother board but not working wirh old mother board. Its not a cable issue or a lcd gouch screen issue.
Punteggio 0
Fingher on show on screen
Punteggio 0
Aggiungi la tua risposta
Gianluca Montanari sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,720
