Salta al contenuto principale
Fujifilm announced the FinePix S5000 Zoom on 29th July 2003.
How do I clean the telescopic barrel?
When I zoom in or out there is a slight grinding noise in the camera. What does this signal as far as the operation of the camera? How can this corrected?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@bert_4221 could be that there is grime/dust/sand in the lens unit mechanism. Of course you do want to clean the outer area of the barrel to ensure it is not carrying stuff inside the unit. Check to see if the spacing of the lens is the same all around so as to ensure it is not misaligned. There are no repair parts for the lens unit available so if anything checks out but it still makes that noise you may consider trying to replace the lens. Check on here for more info
Punteggio 1
Aggiungi la tua risposta
Greg Egnew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 290
