Salta al contenuto principale
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
OL code showing .
When my Kenmore Model 110 washing machine goes to spin the OL code shows up and will not drain.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. If you unplug the washer and follow that procedure, you may find the cause of your problem.
I recommend scheduling for a technician to come out to diagnose and repair your washer.
Hope this helps
Punteggio 2
1 Commento:
i suggest when you copy and paste an answer in from another source you read it completely
da
Aggiungi la tua risposta
Greg Wooldridge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 51
Tutti i Tempi: 7,244
