Salta al contenuto principale
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103 Domande Visualizza tutte
How to reconnect power ribbon cable?
My jbl xtreme power connection as seen in the pictures has came undone. I can push it back into it slot and occasionally it will get a connection and turn on. It doesn't seem to keep connection. So my question is how would I go about fixing this? Could I fix this myself with little electronic repair knowledge and how? Would it be easier to just take it to a repair shop?
https://imgur.com/a/OL3cN
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
You need to insert the ribbon into the slot and then also push the brown part of the connector that secures the cable inward, until you can no longer *easily* pull out the cable.
Punteggio 2
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 376
