Salta al contenuto principale
Guide di riparazione e informazioni di smontaggio per i telefoni cellulari Samsung basati su Android, vecchi e nuovi, compresa la popolare linea di prodotto Galaxy. Cerca tutto il materiale necessario per riparare da te il tuo telefono Samsung.
13156 Domande Visualizza tutte
Adhesive to use to help screen stay on tight?
Hi guys!
So I fix Samsung phone semi-frequently and I've always struggled with using the adhesive which simply isn't as strong as the original type and recently I've had a lady come back several times after fixing her screen complaining that is no longer water proof due to the screen having a slight lift since the adhesive doesn't stick super tight. Is there a type of adhesive that is best to use? I do my best with the adhesive I have but always seems to lift a little. Any advice would be great!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here is the thing, and this should be notated with all customers you deal with.
If you open any unit, you are risking it's water resistance ability. Samsung does not supply their tools to accurately seal devices.
This will also depend on the unit you're working on, I'm going to assume it's a glass back from what it sounds like. If you apply too much heat or use slight force to remove the back, it will be slightly bent out of shape, which is very common. Think of it like tempered glass. Once you apply it and try to remove it, you will have some lift. If this is the case you want to order a new back glass and new adhesive piece for this repair to get the best result.
We attempt to add slight weight when we put the unit back and align it to the best of our ability.
Even with that done, you are still at risk of losing water resistance. The other option, which is believe is more suitable, it to purchase a case.
Hope this helps.
Punteggio 2
2 Commenti:
this is not a %#*@ answer...NAME A BRAND
da
@glove52 You do not need to use foul language if you're attempting to seek assistance. If you look around the shops, there isn't much of a brand nor have I yet struggled with any adhesive from any purchase. There is your &&^&^$^ answer :)
da
Aggiungi la tua risposta
Nina Borseth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 66
