Salta al contenuto principale
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Domande Visualizza tutte
Touch screen malfunction even after reset device
I have this problem which touch screen not working. I had reset by press and hold two button to the ipad but still have same issue after restart. What should i do to fix this?
Appreciate for your advice.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Has anything happened to your device prior to this failure, such as drops/impacts, contact with water or a repair attempt?
The most likely culprit here is the digitizer however because it is fused with the LCD, it will require that you replace the entire assembly. These are quite pricey so you may want to have a repair shop look at it and do it for you if you don't want to buy the replacement parts "upfront". It also requires some soldering to transfer over the sleep/wake sensor.
If you'd like to do it yourself, then look at this guide first to see if you are comfortable with the steps required/
Immagine iPad Air 2 Screen
Prodotto
iPad Air 2 Screen
$169.99
Punteggio 1
Aggiungi la tua risposta
Keith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 420
