Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
20 Domande Visualizza tutte
Camera won't focus properly, especially close up!
I have an iphone 6s Plus, and my rear isight camera won't focus close up and distance photos seem to be low resolution. My front camera takes way better pictures in high resolution and in focus. Also some times the image shakes. Do you think replacing the camera will solve my problem?
I'm on ios 10.3.3
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Replacing the camera fixes the problem. But if you buy the cheap $10 camera on alibaba those are clones. They work, but it doesn’t take great pictures like an original camera.
Punteggio 0
Risposta Più Utile
Unfortunately, there's only one way to find out. The 6S Plus camera has optical image stabilisation and that is probably what is at fault here. Have you dropped your phone recently?
If you want to rule out any potential software issues, do a full backup then start with a hard reset (Home & Power Buttons for 10 secs). You could also try a full DFU restore which will re-install iOS from scratch.
If those don't work, or if you choose not to try them, then order a replacement camera and follow this guide.
Immagine Replace a 12 megapixel rear-facing camera compatible with the iPhone 6s Plus. Fix focusing and sensor issues.
Prodotto
iPhone 6s Plus Rear Camera
$49.99
Punteggio 4
This video will help you fix instantly that problem
https://m.youtube.com/watch?v=4z8GCVXCtY...
Punteggio 0
Where you able to fix it?? I have the same problem on a 6S on ios 13
Punteggio 0
Aggiungi la tua risposta
jimmylasvegas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,762
