Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
volume buttons not working on iPhone 4s
Hi there, my volume buttons don't work and some weird issue with the speaker on my iPhone 4s.
When I go into Settings-Sounds and click on 'Ringer and Alerts' the volume buttons work and I can hear the sound through the main speaker but when I go into the main home screen they don't work. I tried to put in silent mode and than into normal mode but still don't work.
When the headphones are connected they work fine but as soon as I remove the headphones they stop working.
Also, when I try to play videos the sound doesn't work probably becuase the volume is turned to minmal which I can't control. Through headphones it works fine but as soon as there out no sound comes out.
I've openend the phone and removed the buttons, gave them a good clean with alcohol along with the circuit board but after installation the buttons still don't work.
Is there something I can try to do to fix this or do I need new Headphone Audio Jack Volume Mute Silent Switch Button Cable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you tried replacing the button cable? Sometimes it could short and would need replaced.
Punteggio 0
2 Commenti:
Thanks Jennifer will try that, is that the main ribbon cable or just the + & - buttons unit?
da
Not sure what you mean by main ribbon cable but volume button cable comes in as a whole piece.
da
Aggiungi la tua risposta
Adrian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 438
