Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake" e 4 porte Thunderbolt 3.
How to Repair the black strip that says MacBook Pro
Hi I noticed something got stuck in the crack where the screen folds down. Now I have a pressure crack/ hole. can that plastic strip be replaced instead of replacing the whole screen etc..
Thanks
Julie
Questa è una buona domanda?
Punteggio 3
3 Commenti
Have you repaired it? I have the same problem, happened today
da
It can be replaced. I have seen these parts available.
da
Where can you buy the parts? I have the same issue with my 13" Macbook Air too
da
Aggiungi un commento
2 Risposte
Risposta più utile
Yes the chin plate can be replaced! Here’s the part: Chin Plate and here’s a guide that can help you see what’s behind it Sostituzione cornice logo schermo MacBook Pro 15" Touch Bar 2017
Punteggio 1
Yes, it is possible to replace the black strip at the bottom! I’ve actually done it a few days ago and it’s fairly simple. First you need to have a source of heat and heat the bottom strip as it has adhesive on it to keep it stuck down. Once you’ve heated it a bit you need to find something to pry the strip up. You can use anything that’s thin enough to fit into the side of the strip to pull it up. I suggest starting from the corner as under the strip are a few ribbon cables for the display so be very careful! Once you’ve got one corner up just make sure to heat it up as you go along to make it a lot easier. Once you’ve got it completely off make sure you take out any remaining pieces or shards from the old strip. Then you’ll be good to place down your replacement! I hope these instructions were descriptive enough to guide you through the process :)!
Punteggio 0
1 Commento:
Oh man is this an old post. I just checked the date of when it was posted.
da
Aggiungi la tua risposta
swimmer35 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 36
Tutti i Tempi: 3,478
