Salta al contenuto principale
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
20 Domande Visualizza tutte
When I insert the wisk or K-part it comes apart after a few seconds
Sorry, my English is not really good.
My Kenwood Chef works and rotates, but when I try to mix butter or dough, it turns itself loose and the middle screw (at the axis) falls in the dough.
It started after kneeding a tough christmascake last year ;-(.
Here is a clip of what happens.
https://youtu.be/bGVAsRTYXCM
Can anyone give me advice how to repair it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Take the central nut off. Try and remove the planet hub by wiggling it with a downwards motion.
Check that the gear (cog) on top of the beater socket is not damaged (sometimes they’re made of plastic and have broken or split). If necessary fit a new gear (available online) and secure with a 5 mm starlock washer/push-on fastener. Whilst its off you could clean off any old dirt/grease using a cloth with some white spirit, and re-lubricate around the teeth on the underside of the gearbox with a smear of grease. Also check that the hole in the middle of the hub is still “D” shaped - these can wear down with age.
Replace the planet hub and refit the nut using a new washer (plastic or fibre) between the planet hub and the nut. An M6 nylon washer should be the right size. Do the nut up with a spanner, but do not overtighten as you don’t want to strip the threads. Note that there may be a small gap between the hub and the nut if the new washer is thicker than the original. This will not affect operation.
Punteggio 1
1 Commento:
If the "whole in the middle" of the planet hub is no longer "D" shaped, do I need a new planet hub, or is there a fix? Thanks
da
Aggiungi la tua risposta
Bregje Kaars Sijpesteijn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 27
Tutti i Tempi: 952
