Salta al contenuto principale
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
20 Domande Visualizza tutte
White Lines just popped up on tv screen
Getting lines down tv screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Uh oh. I had this happen before and turned out to be a blown capacitor on board. I had dismantle the back panel and searched the entire board. When I found the capacitor i knew it may be the culprit because all capacitor are flat on the end and this one was rounded. Took a soldering iron to remove as much solder as I could from the capacitor spot and then I took a heat gun to it to pull the capacitor. Be sure to use that yellow heat disapating tape around the capacitor so you don't over heat nearby capacitors. Find the same capacitor on eBay and that was it for me.
Punteggio 0
Aggiungi la tua risposta
Charletta Tucker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 504
