Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 era a quel tempo il top della gamma Galaxy. La versione con schermo curvo è nota come Galaxy S6 Edge.
Dropped phone; turns on only when plugged in wall
I dropped my phone some time ago and unles it's plugged into a wall charger it won't come on. The phone has no cracks or anything so I suspect that there is some type of disconnect. I have tried troubleshooting by charging it all the way and then trying to turn it on after a little rest and I have done a factory reset as well. Neither of those things worked, unfortunately.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@miraculyfe if it works on your wall charger but not while it is unplugged, check the battery. Make sure that all contacts are properly seated and ultimately you also want to try a new battery. It is a beast to do anything related to the battery on this phone as you can see with this guide
Punteggio 2
Aggiungi la tua risposta
Lakendria Bledsoe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,402
