Salta al contenuto principale
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180 Domande Visualizza tutte
Screen turns grey when powered on. Can the screen be the only problem?
When I turn on my phone the screen wont show anything but a grey screen. The notification light at the top works just fine. Is the screen the only thing that needs to be replaced.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
robin koort it is possible that this is a screen damage. Of course it could also be the motherboard itself. I'd go with the easier and cheaper and replace the screen. Of course you do want to check all the ribbon cables and connectors as well and check to see if you can identify any obvious damaged components. Use these guides to work on your phone.
Punteggio 2
Aggiungi la tua risposta
robin koort sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 833
