Salta al contenuto principale
The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
375 Domande Visualizza tutte
My charger plug won't plug in.
My charger plug seems to be blocked from plugging in.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Does it seem to be blocked by an object in the plug? If not, does the connector seem fine and not damaged? It that looks fine, have you tried a different cable just to be sure that it is not the cable that is bad?
Punteggio 1
1.Lighting the charging port to see if there is something else.
2.Check whether the cable and charging port are in good condition? If the cable is damaged, change a new one to have a try, if the charging port is damaged, you should replace a new charging port.
Punteggio 1
Aggiungi la tua risposta
Rich Stanley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 14
Tutti i Tempi: 159
