Salta al contenuto principale
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
99 Domande Visualizza tutte
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Questa è una buona domanda?
Punteggio 2
7 Commenti
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
da
Different battery perhaps?
da
Do I have to try with a different battery? Can it be a motherboard's problem ?
da
Yeah, it could be either the mother board or the battery.
da
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Immagine Asus ZenFone 2 Batteria
Guida
Sostituzione Batteria Asus ZenFone 2
Difficoltà:
Difficile
20 minutes
Immagine Asus ZenFone 2 Scheda madre
Guida
Sostituzione Scheda madre Asus ZenFone 2
Difficoltà:
Moderato
15 minutes
Punteggio 2
1 Commento:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
da
Aggiungi la tua risposta
Vincenzo Liguori sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 378
