iMac has no power
The imac does not turn on. No power.
Questa è una buona domanda?
Before spending any money on this machine, please open it up (it's very easy to do, only three screws), examine the logic board capacitors (cans) for swelling and/or corrosion. Then plug it in, using the eraser tip of a pencil press the reset and restart buttons (CUDA switchs) located right by where the SATA hard drive cable plugs into the logic board. Observe the diagnostic LED lights in the center of the logic board. You will probably see number one on and the rest off. If the cans are good, then I would replace the power supply. If bad, you're wasting your money.
I have firlse led on and rest off and when I opened the power supply a few cans have dried orange stuff on top. Ordered a used one with dif brand from ebay. Will uodate soon.
These models were notorious for having bad capacitors, both on the logic board and in the power supply. Before spending any money on it examine the capacitors on the logic board for swelling and/or leakage. Take out a square trade warranty on the power supply you ordered if it was used. Use this code to get a 20% discount: https://www.squaretrade.com/allplans20?c...
Harvest20
You may have fallen victim to the bad PSU issue these iMacs have...
Here's the part you would need to replace
[prodotto collegato mancante o disabilitato: IF165-001]
and the instructions on how to do it
How do I fix it
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,393
