Why is the volume when playing from turntable very low
Volume is very low when using the Technics SL-1700 turntable
Questa è una buona domanda?
Hi!
Turntables will output high quality sound only if they are connected to a pre-amplifier. These devices are different from normal amplifiers in that they only take the raw sound from the turntable and make it louder. Having the turntable only connected to a standard amplifier will not be the same, the sound will be played back at a very low volume.
Make sure the turntable is connected into the phono input on the back and the dial is turned to phono on the front. Then there is a little button around the back (you might need a matchstick to press it as it’s countersunk from memory) which toggles the input between ‘normal’ and phono. You want it switched to phono. Good luck!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 858
