Salta al contenuto principale
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Domande Visualizza tutte
iPad 4 Broken Screen issue
Can someone tell me what part I need to repair this?
https://youtu.be/R4MMkXS1MrA
https://youtu.be/OcyWpvNMPoo
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The front glass is the digitizer it's usually a single piece bonded together lens and digi together behind that is the lcd... if it's already cracked or scratched you might as well change the digi anyway
Punteggio 0
1 Commento:
Thanks for your help!
da
U seem to need the lcd and you might as well order a digitizer as well in case you break it when your trying to remove it.
Punteggio 0
2 Commenti:
So they sell the LCD, which is apparently behind the glass. So I need to order the front panel, the LCD, and the digitizer. Correct?
iPad 4 Screen Digitizer Assembly
iPad 3/4 LCD
da
The front glass is cracked.
da
Aggiungi la tua risposta
robbieleffel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 99
