Salta al contenuto principale
Which screen replacement should I order?
Hello,
my A1398 macbook screen is broken and needs to be replaced. Apple Ireland quoted 900 euro replacement cost. which is too expensive for a screen replacment!
Anyway, I am good in DIY stuff, but I need your help picking the right part for my mac?
I mean what exactly should I order to replace the broken screen?
thank you in advanced :)
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
You need to search for the year and size. For example, "Macbook Pro 15" Mid 2014 screen assembly". You would look up that screen, and you would want the full display assembly, which is the top half of your laptop (LCD, case, cables etc).
If you don;t know your model info, you can look up the serial number here http://www.everymac.com/ultimate-mac-loo...
The part should look like this
Punteggio 0
2 Commenti:
Thank you, David.
The model number is A1398
It is a 15" retina screen for a mac book pro which I bought in 2014 summer.
I still can't find the part I need to order in Ifixit store.
da
"https://www.ifixit.com/Store/Mac/MacBook...[Displays]=on"
Use this link, then you can filter by displays. Most likely the late 2013/mid 2014 model, but you should definitely enter your serial number in the link I posted earlier and verify.
da
Aggiungi la tua risposta
Bayan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 125
