Salta al contenuto principale
Repair and troubleshooting documentation for Frigidaire dishwashers.
Dishwasher fills with water and then turns OFF!
I have Frigidaire dishwasher. It will fill with water and drain when I hit the drain button, but Turns OFF after it fills with water.
This happens to whatever cycle I choose,
Normal wash, Quick wash, rinse only
It just fills up with water and then Turns off,
I have to turn it on again and press cancel to drain the water
I appreciate if anyone can help
Thank you
Questa è una buona domanda?
Punteggio 0
2 Commenti
I have the same issue only it will fill up then stop. Then restart but no water. It will run thru the whole cycle with out any water coming in to the dishwasher.
da
Kill the breaker for 60 seconds to reset board. If it comes back, replace the board.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Cause 1
Thermal Fuse
The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
Cause 2
Door Switch
The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Latch
The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
Punteggio 1
6 Commenti:
Thank you
I will try the solutions you have suggested and see if it can be fixed.
da
How will a dishwasher fill up if it has a bad door latch?
da
@abamadude It shouldn't
da
My dishwasher drains water at the start of the cycle and then fills up but nothing after that.
Help please
da
david same answer as stated above, if you provide a make and model number maybe I can add something.
da
Mostra 1 altro commento
Aggiungi la tua risposta
khoshakhlagh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 19,396
