Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Black Screen iMac, external working changed backlight board
Hello,
I'm having an oddly specific problem with my iMac.
I have a couple fixer uppers that I am working on, and I put a new GPU in one and put everything together only to find that the LCD wasn't working, though everything was working through external monitor and all four LEDs on motherboard were lit.
I pulled the LCD from my other computer, which I confirmed was working before switching. The LCD was still completely out, so I scavenged the Inverter board as well, which yielded nothing.
To be clear, the screen is completely dead, and I wasn't able to see my desktop at all when I shone a light on it, so I don't believe its simply a backlight problem.
Any help would be greatly appreciated as I'm not sure where to turn at this point!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
First hook it up to an external monitor and see if the GPU is generating a signal.
UPDATE
Your best bet at this point is to replace the LED driver board:
iMac Intel 27" EMC 2429 LED Driver Board Replacement
Punteggio 2
2 Commenti:
I have and the computer is fully functional through the external monitor. I can detect the GPU (radeon 6790 1GB VRAM I think?) on about this Mac on the monitor as well.
da
Sorry, I guess I had my terminology wrong in the original question. I pulled a working LED Driver Board and installed it to no avail.
da
What is the voltage in your outlet please?
Punteggio 0
2 Commenti:
Anna, let's solve your problem first, please.
da
standard US outlet, 120 volts 60 HZ though I don't have a way to electrically test that
da
Aggiungi la tua risposta
Joseph Rushkin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 140
