Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
Punteggio 1
Risposta Più Utile
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
Punteggio 5
4 Commenti:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
da
You are fine then, just use the original home button:)
da
Taylor, you accepted the wrong answer ;-)
da
@mayer at least she got an answer she is happy with ;-)
da
Aggiungi la tua risposta
Taylor Fuller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 68
