Salta al contenuto principale
Repair guides and support for your Sanyo TV.
Why tv keep swatch the source
it keep jump to the input it flashing number and say hdm1 23 and flashing pc vedro
Questa è una buona domanda?
Punteggio 1
1 Commento
It is more likely that it's a problem with the input to the device than the TV itself.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
@sweetoea unplug your set from the electrical outlet to reset it. Unplug everything connected to the back of your TV. Then plug the set back in and only connect one source i.e. Cable TV. If that works then add one device after the next and see if it works.
Punteggio 2
It has not done nothing but making noise noise it's unbearable to listen off a blank picture.
Punteggio 0
I can not get my Service from the Sanyo tv.
Punteggio 0
Aggiungi la tua risposta
carlita smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 242
