Salta al contenuto principale
Can I repair the cracked screen myself or that not recommended?
I've been hooking my laptop to a display unit, but I would like to get the screen fixed. Anyway I can do it myself, or is that not recommended?
If not recommended, who would be best, and least expensive, to get it done in North SF Bay Area?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check out this link for a tear down of the display assembly: MacBook Pro Retina Display Teardown
Also check out this youtube video: https://www.youtube.com/watch?v=h5MLalnT...
As for changing the cracked glass... It can be done, and after looking at the teardown and the video you can determine whether this is something you want to do. I couldn't find a supply of only the glass, but if you want to attempt this, then maybe you'll have better luck. You can always buy a used display, and salvage the glass from it.
The other option is to replace the entire display assembly. You can buy that from ifixit: MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly, and use this guide: MacBook Pro 13" Retina Display Late 2012 Display Assembly Replacement
Immagine MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
Prodotto
$429.99
Immagine MacBook Pro 15" Retina Display Mid 2012
Guida
Difficoltà:
Moderato
Immagine MacBook Pro 13" Retina Display Late 2012 Display Assembly
Guida
Difficoltà:
Moderato
20 minutes - 1 hour
Punteggio 1
Aggiungi la tua risposta
Judy Tipple sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 51
