Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
iPhone does not recognize any Sim
Hello,
My iPhone does not recognize any Sim.
What part do I need to replace / fix?
Thanks (
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
if this is a phone that is new to you- I would check the imei to make sure it is not listed as lost/stolen
clean the sim card
check sim tray for bent/dirty pins.
the paper under sim tray is a great idea..
Punteggio 2
Well... Try to put a paper or something thin (~1mm) between the tray and the SIM then put it on the phone.
I can't guarantee you that this will work but why not trying?
Punteggio 1
Please check if your iPhone have carrier lock or not ? If it is locked with any carrier, that sim only works in your iPhone . If you want to use it with other networks, you need to unlock it from the locked network . For that, you can get unlocking servcie from your service provider or from any of the online vendors like Prounlocking.com to unlock it . Once, you have removed network restriction from your iPhone, you can use it with any other GSM carriers internationally .After that, it won't accept/not recognize any sim card, it may be hardware problem .
Punteggio 0
Aggiungi la tua risposta
or erel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,650
