Salta al contenuto principale
Released March 2016, 7.0" Galaxy Tablet by Samsung.
20 Domande Visualizza tutte
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If you are charging it via your computer, switch to a charger.
Punteggio 3
1 Commento:
No, im charging it with its charger. But there still an X mark
da
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
Punteggio 0
1 Commento:
I’ve got a 51 located on the battery icon. What does that mean
da
Mine does the same thing but I just got a new battery so I know it’s not a battery problem.
Punteggio 0
Aggiungi la tua risposta
aju shee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 13,617
