Samsung Galaxy S7 Broken Data Recovery
Hi. My Galaxy S7's screen is broken, and I cannot do anything on the phone now. Is there any Samsung Galaxy S7 broken screen data recovery available to recover data from broken S7?
Questa è una buona domanda?
I think you can refer How to Recover Deleted Photos from Samsung Galaxy S7 Edge? to get a solution. Many android data recovery app has include such a feature to extract data from broken android. You can get one to recover your data
Thanks for your help
Let's see if you're phone will register touch, lets hope you don't have a lock pattern or this might get more complicated.
Download Smart Switch
Plug device to computer
Smart Switch will tell you either the phone is lock. If you know the unlock code try to access the phone through the broken screen. After that you need to tap "Allow" to allow smart switch to back up the unit.
This is located in the center right. I would just tap around to see if you magically hit the button.
If you're able to do this, you can successfully back up. If not, then sorry.
If you're confident in the screen replacement then do so. Otherwise go ahead and bring it to a technician. Data should not be lost during the repair, however stuff happens. So this will not be a guarantee.
Good Luck
it is asking for me to push install button after updating but i cannot see me screen help!
The Install should appear on the top right corner of the screen.
If you have connected your phone to your PC/Mac before you can connect it up to SmartSwitch and backup all your data you may have to connect it as a media device. Failing that you should be able to take it to a repair store and have them just attach a screen to it and back it up that way. Thats the service i offer to customers anyway
Hi jamess, why not change a new screen for it then you needn't to Data Recovery.
250.00 dollars to replace screen insurance already replaced phone need data.
Considered that your phone's screen is broken, but if the USB debugging is already enabled, then you can extract files from s7 to your laptop. But this method can only recover part of your data. Besides, you can try to create a backup file via Samsung Smart Switch or Android Data Extraction. Hope this can help you recover data from Samsung Galaxy with broken screen.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 49,355
