Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Replaced front facing camera but the camera displays a black screen
I recently bought and replaced the front facing camera on my iphone 5, after i was doe with the replacement the front camera would show a black screen. I tried to restart my phone, and it still didn't work. I don't know if i did something wrong during the repair or i'm not doing something so the camera works. Please help!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hello! If the camera is showing a black screen that means the phone is not communicating with the camera. Try reconnecting the cable. Make sure it's the right way.
Punteggio 1
1 Commento:
Hi. I tried reconnecting the cable twice and still the camera displays a black screen
da
Have you Re-booted the phone? If that doesn't work just check to make sure that there is nothing covering the actual front camera. Failing that id say its dodgy
Punteggio 0
2 Commenti:
If this works, please tell me, thank you.
da
I have tried this multiple times and still nothing.
da
Since you've done what the other two answers say then it is one of two things, either a faulty camera, or something is damaged on the flex cable/connector.
Punteggio 0
Aggiungi la tua risposta
miloasoc sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 188
