Salta al contenuto principale
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Domande Visualizza tutte
What kind of connector is this?
Hello everybody,
i wanted to change my Broken 160 GB HDD from my iPod classic. I used the guides to open the iPod.
An already purchased a so called 'iPod to CF adapter' and a CF-SD Adapter. After I the iPod was open i saw that the HDD connector is some kind of Small foil cable an very Small. So my request, does someone know if I can change maybe the cable to fit the Adapter or what can i do? I really would like to use the recently purchased
adapter if possible.
I took pictures of the Parts:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well you got the wrong part. An adapter is used when changing to a different thing.
Just get the correct parts to start off with. It's $2.75. Trying to use the wrong part will drive you up the wall.
Here's the correct part: http://www.powerbookmedic.com/iPod-Class...
Punteggio 1
1 Commento:
Hi,
thank you for the fast answer but I'm not sure what to do with this Info: I want to swap the HDD into an SD card with an iPod cf Adapter and inside the CF slot an CF SD Adapter. But it seems the Adapter I got is the wrong one. The cable was allready inside the iPod. What kind of Adapter is the correct one? I
Sorry If I'm kinda slow, normally i don't do these kind of things.
da
Aggiungi la tua risposta
Andreas Zehetner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 121
