Salta al contenuto principale
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
Questa è una buona domanda?
Punteggio 2
2 Commenti
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
da
Hello
I have the same problem, did you find a solution?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
Punteggio 1
1 Commento:
8 minutes ago by Gabriele Filoni
da
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
Punteggio 1
1 Commento:
Thank you very much it works!
da
Aggiungi la tua risposta
Gabriele Filoni sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,201
