I crank the engine and no Start fast
I crank my engine but no Start fast and when i stop and teñirse the brakes and pres gas the car no have power.
Questa è una buona domanda?
Your car sounds like it needs a tune up . You may need to replace the air and fuel filter . New plugs and wires as well , a new PCV valve will also help. If the engine is throwing any codes they should also be addressed . Do you have any MIL lights on on the dash ? If so get an OBDII reader and find out what systems are effected. Service your car and it will run well ignore the maintenance and it will run like crap . Hope this helps
BTW don't forget regular oil changes
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 96
