1- Have you tried running this iBook without the battery ?
A defctive battery cell could possibly cause DC overload.
2- Possibility of a defective fan inside the iBook.
3- If you open it, also consider changing the PRAM battery to solve the date and time isue.
4- Have you had a chance to try an other power adapter ? If you try an other one, make sure it has the same power (or higher) as the original.
5- Most computers are equipped with an inside cooling fan to prevent overheating (yours definitely has one); is your fan running after a few minutes ? If not, perhaps it is jammed or it has a heat sensor issue. This can also shut down your computer after a few minutes.
6- As for the PRAM battery, sorry for misleading you earlier, I just read in an other article that iBooks G3 and G4 don't have PRAM battery, so if your battery is dead, you will loose parameters like date and time.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
