Salta al contenuto principale
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
steps to reboot after replacing battery
battery replaced but tablet will not reboot. after charging LED blinks three times. what are steps to reboot?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
How long have you kept it on charge? In some cases some batteries are dead flat and take a long time to even just show the charging logo on screen.
Punteggio 4
1 Commento:
Thanks for the insight. I went ahead and ordered a SONY charger/cable. The battery is a new SONY replacement battery just installed by a tech. The tech advised that sometimes using some other cable results in not charging correctly. Since I was using some other cable the battery LED indicator never changed from red. In my attempt to reboot the tablet the LED blinked 3 times. I thought there was some trick to rebooting the tablet after installing a new battery. I'll charge the tablet using the OEM and hope to get the green light.
da
Aggiungi la tua risposta
Carlos Gonzalez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 194
