Salta al contenuto principale
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
19 Domande Visualizza tutte
Why do I not have any acceleration
I have a 2005 Nissan Murano se I've replaced the alternator, the accelerator pedal sensor, the throttle control body, and the thermostat as the codes was throwing up on the obdm. I have tried clearing it out and the codes go away for a minute but come right back. I also did the relearn on it. Help me please...codes are 1122...etc actuator malfunction.....1126 thermostat stuck open...but I replaced the thermostat. I can't get the codes cleared out for some reason
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
it might be the about to alternator burn out
Punteggio 1
I just started expiriencing the same issue with my nissan ive replaced the throttle body but cant get the code to clear or even accelerate but i'm working on it soon as i get it fixed i'll let you know(code 1122)
Punteggio 0
Aggiungi la tua risposta
Jennifer Logan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 52
Tutti i Tempi: 1,277
