Salta al contenuto principale
Model A1138 / 1440x960 screen resolution
85 Domande Visualizza tutte
Why does OS X sometimes crash on startup and shutdown?
It doesn't happen all the time. Have run disc repair from install disc. One of the letters "m" has to be manipuated to work. Movie downloads sometimes freeze or crash on iTunes. Took it into Apple and tech looked at the data history and said it was probably a hard drive issue. But, I here no clicking in the drive. I have everything backed up. Just wanted to make sure there was something else I could try before I put in a new hard drive. Re-install O SX maybe? Thanks. Mike
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you have a good backup, such as Time Machine, I would zero out the drive. This writes zeros to every block, it's found in the format options. This will map out any bad blocks that may have developed. Then restore your data.
Punteggio 1
Aggiungi la tua risposta
Michael McGuire sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 816
