Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How to determine if Flex Cable or Top Case defective?
Hey guys,
my A1181 stopped working from now to then.
So I checked all voltages and stuff, everything was fine. The last try was the one I should have checked first: Just shortened the two pads on the board and voilá, everything is back.
So how can I see what I should replace - just the cable or the whole topcase? My multimeter probes are too large for a continuity test on the cable. But at least it looks good :)
Are there any tests I could do with the topcase or is there anything I can fix without totally damaging it? I see it is held together by just plastic "bolts" which would be destroyed. Am I correct?
I did not see a Teardown of the Topcase revealing its power and data lines so I’m curious if this is even fixable.
Cheers
Jonas
Questa è una buona domanda?
Punteggio 0
2 Commenti
There are 17 machines with the A1181 designation. Please pick one: http://www.everymac.com/ultimate-mac-loo...
da
Dear mayer, The question is regarding the top case which is the same on all models (but the flex cable) - I posted all relevant information. I was more rude before I read your "about" - though I’m still wondering why it is important which model is below the top case. It’s a 820 2496A. Regards to LBB
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I ordered another topcase from classifieds and it turned out that it was the flex cable! Weird as it wasnt moved so I would not have the idea that this cable can be worn out like the one for the inverter or similar which is moved oftn.
Punteggio 0
Aggiungi la tua risposta
jonase sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 189
