Salta al contenuto principale
My memory card gave me a headache
I bought a memory card 20 days ago. It was working till 7-8 days after that one day in the early morning it damager itself. Now it can't be detected by my device and computer. can I fix or repair it ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hey there,
You could first try and check the memory cards themselves to make sure that both are working. If you have two or more RAM slots, swap the card into another slot and see if the computer detects it. If the card is detected after changing the slot, then it could be that the particular RAM slot is malfunctioning.
Also be sure to check the card for any type of damage/ loose pieces/ missing pins, etc. Checking the RAM slots themselves for any debris or loose connectors could be useful.
It is rare for a cpu to have an issue but in most modern cpu's the ram controller is a part of the cpu, meaning if you have a non working slot or multiple, it could be the board or the cpu.
Feel free to check out this link as well.
Punteggio 0
Aggiungi la tua risposta
Naresh Chaudhary sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 46
